Fusion Manufacture
CHAMFER NOT FINISHING THE CHAMFER
2 REPLIES 2
Wbaker1859
99 Views, 2 Replies
CHAMFER NOT FINISHING THE CHAMFER LINE
Tags (3)
2 REPLIES 2
seth.madore
in reply to: Wbaker1859
Would you be able to share your Fusion file here?
File > Export > Save to local folder, return to thread and attach the .f3d/.f3z file in your reply.
It looks like you may have multiple bodies in your Setup 🤔
Seth Madore
Wbaker1859
in reply to: seth.madore
Thank you Seth for the quick response and you were right I had a mirrored version of the body hidden but found a work around to fix the issue. But if the multiple bodies can cause processing issues I will not leave them in even when they are hidden. Thanks as always for yall's quick response time; its on me not following up to get the correct solution but we got the job done anyways.
