06:01 AM
Hello again 🙂
If importet a .ipt from Inventor 2017 into Fusion and like to set it up for 5axis milling.
Most of the things is no Problem. But there is one quite serious one:
I'm not able to select a face wich was created using the chamfer tool (in inventor). Means if I've got a Chamfer 15mmx45° wich I'd like to use a face mill, I can't select it with the 2D Plane function!?
But also for smaler chamfers (like 1mmx45°) I'm not able to make them with a chamfer tool when selecting the bottom path of it (if there is one, otherwiese I still don't know how to do them)
Had anyone similar troubles?
Regards Sam
Link copied
