Chamfer inside a hole Impossible to do it Intelligently
dudu_268
dudu_268
Hello
I'm trying to do a 45ยบ chamfer inside a hole with a chamfer mill.
The hole smaller diameter is 6.1mm and the bigger 12mm and of course there is already a Pre-Drill.
Does anybody can do it with this tool?
I attached images with tool and hole dimensions.
porsbym
Try a 2D Contour with the upper edge of the chamfer selected for the geometry. It compensates for the tip of the tool by default, but you can adjust that using heights or axial stock to leave.
2D Contour also has additional chamfer options available on the passes tab when using a chamfer tool. You don't need those in this case, though.
/Mark
dudu_268
Thank you man!
It worked and I didn't have to use the stock to leave feature.
porsbym
You are quite welcome. Glad to hear that it worked!
