cant seen get this part to post on the haas with 4 axis post
crunichie
crunichie
i have attatched program and ur the post from fuison libary for the 4 axis pre gen haas it not letting me work on the 2 side face it only letting me work on the A0 face and A180 face
am i missing some thing as i keep get this message on all the face i working on that not A0 and A180
Warning: Tool 2 has multiple usages with conflicting geometry.
Warning: Tool 5 has multiple usages with conflicting geometry.
Information: Configuration: HAAS - A-axis (pre-NGC)
Information: Vendor: Haas Automation
Information: Posting intermediate data to 'C:\Users\AFTCAD\AppData\Local\Fusion 360 CAM\nc\1001.nc'
Error: Failed to post process. See below for details.
Code page changed to '1252  (ANSI - Latin I)'
Start time: Thursday, October 152020 7:47:37 AM
Code page changed to '20127 (US-ASCII)'
Post processor engine: 4.5718.0
Configuration path: C:\Users\AFTCAD\AppData\Local\Autodesk\Autodesk Fusion 360\Q95SJ2TVY9XA\W.login\M\D20190901212164176\CAMPosts\haas with a-axis 2.cps
Include paths: C:\Users\AFTCAD\AppData\Local\Autodesk\Autodesk Fusion 360\Q95SJ2TVY9XA\W.login\M\D20190901212164176\CAMPosts
Configuration modification date: Thursday, October 152020 7:01:07 AM
Output path: C:\Users\AFTCAD\AppData\Local\Fusion 360 CAM\nc\1001.nc
Checksum of intermediate NC data: 9e731414cffea01924067c49675857b1
Checksum of configuration: 51f7ff1e8f7947d1f08da21901e681a3
Legal: Copyright (C) 2012-2020 by Autodesk, Inc.
Generated by: Fusion 360 CAM 2.0.9011
ErrorError: Direction is not supported for machine configuration.
Error at line: 1
Error in operation: 'Horizontal1'
Stack dump:
("Direction is not supported for machine configuration.")@:0
getWorkPlaneMachineABC([object Matrix],false)@C:\Users\AFTCAD\AppData\Local\Autodesk\Autodesk Fusion 360\Q95SJ2TVY9XA\W.login\M\D20190901212164176\CAMPosts\haas with a-axis 2.cps:965
defineWorkPlane([object Section],false)@C:\Users\AFTCAD\AppData\Local\Autodesk\Autodesk Fusion 360\Q95SJ2TVY9XA\W.login\M\D20190901212164176\CAMPosts\haas with a-axis 2.cps:872
onSection()@C:\Users\AFTCAD\AppData\Local\Autodesk\Autodesk Fusion 360\Q95SJ2TVY9XA\W.login\M\D20190901212164176\CAMPosts\haas with a-axis 2.cps:1343
Failed while processing onSection() for record 6102.
Error: Failed to invoke function 'onSection'.
Error: Failed to invoke 'onSection' in the post configuration.
Error: Failed to execute configuration.
Stop time: Thursday, October 152020 7:47:37 AM
Post processing failed.
try every i can see all being same wc dircestion and that but only get half program to work please help
any help fast be great as holding up machine at moment due can get post to work but can get work on 5 axis  but not are pre gen control with 4 axis
daniel_lyall
10th toolpath down from setup one the Y is in the other direction.
@seth.madore Can you please have a look at this?
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
crunichie
Yea clock that when flicking through he tool path so used to set 5 axis on tr160 forgot that the 4 axis on other mill is in x axis and not y lol thanks
seth.madore
All of your orientations are setup as if your machine has a B axis, not an A. I suspect that if your post is modified to reflect that it's actually a B axis, you'll get the code you need
Seth Madore
daniel_lyall
One thing @crunichie chucking the toolpath at a different post can show where the error is, with your one the UMC post had a fail, it was hitting a B C move it did not like in one of the paths.
Daniel Lyall
The Big Boss
Mach3 User
