cant delete tool library
nubrandao
nubrandao
hi, im importing tool data base from powermil to fusion.
i imported  two data bases succes, one of them gave an error, appears in red and dont allow me to delete...its shows error "fail to import"
how can i delete? cant find the folder
Replies (8)
jeff.pek
Which section of the tool library did you import it into? Local? Cloud?
Jeff
nubrandao
local
jeff.pek
On Windows, the local tool library files are in %appdata%\Autodesk\CAM360\libraries\local.
Jeff
nubrandao
still cant find, my windows is 10 , since is in the company, maybe cant acess, there are lot of restricions
jeff.pek
I wouldn't expect that area to be restricted. It would be under c:\users\<userid>\appdata\roaming.
Jeff
nubrandao
i will try it tomorrow..what files should i delete? what type of files extension?
jeff.pek
They would typically have a ".json" extension.
nubrandao
fixed..was in roaming folder.thanks
