Fusion Manufacture
Cannot move inserted object.
2 REPLIES 2
ian1196
69 Views, 2 Replies
I want to nest multiple parts to mill. I start with two objects in two files. I open one file. I right click the other file in the folder and "Insert into Current design". I can move the inserted object. I make my tool paths and I need to move one of the objects and repeat. However, after I accept the position of the inserted, I cannot move the inserted object. I can move the original part but not the inserted part. If I have multiple inserted parts, how do I move them?
2 REPLIES 2
ian1196
in reply to: ian1196
Today, It seemed to work if I treat it as a component.
seth.madore
Are you using the Nesting or the Arrange workflow?
Are you manually moving things into position, or are you using joints?
Seth Madore
