Cannot Make Tool Library Work for Me!
billB2FDG
billB2FDG
1.  I am having a terrible time with renumber tools.  It simply will not order and renumber the tools according to the milling process I have set up.  I final went to edit tool, Post Processor Tab, and physically changed the tool numbers there.  I can no longer revert to the old Tool Library, correct?
2. Also, I had some tools saved for different S&F's; they are gone!
3. Where is "remove unused tools" option?  Once in a while it shows up but still warns that the tools will be deleted from the library and will no longer be available.
mattdlr89
1. I haven't used the renumber tool functionality so can't comment on that. But it is possible to revert back to the old tool library by turning it off in preview if that fixes the problem?
3. It seems to remove the unused tools you have to right click on the document in tool library and then select remove unused tools. I don't think there is any other way to do it. See screen shotā€ƒ
Ketherton21
you can still revert! see picture attached
billB2FDG
Thank you!
Sometimes I see ā€œRemove Unused Toolsā€, but then the warning comes up, the tools will be deleted from the library.
engineguy
@billB2FDG
Small screencast with Audio so turn your sound on if it is on mute, shows the tools being ordered and renumbered, hope it helps, yes a lot different but does work :slightly_smiling_face::slightly_smiling_face::slightly_smiling_face:
Regards
Rob
billB2FDG
Thank you!  Very helpful!
