Fusion Manufacture
Cannot get a chamfer on this part
2 REPLIES 2
cdevrard
132 Views, 2 Replies
I am getting a "empty toolpath" message. The chamfer is not modeled. I copied these two chamfer operations over from a previous version of the part where they were working fine. Then I tried deleting them both and starting with brand new 2d chamfer operations. No dice.
The only thing I can think is that something in the modification of my part is causing the problem. I sure cannot figure out what it is though
f3d attached
Thank you!
Chris E.
2 REPLIES 2
seth.madore
in reply to: cdevrard
Hey there 🙂
It's because you have this selected in your Setup:
When making a Setup, you really should only include the bodies you plan on cutting, or using for Fixture definition. In your Setup, I selected ONLY the part we're machining:
Seth Madore
cdevrard
Thank you so much Seth. I'd have never thought of that!
Chris E.
