Fusion Manufacture
Cannot find a best way to remove material and saving time.
5 REPLIES 5
ransomewarewanasmile911
198 Views, 5 Replies
Link my part for viewing     https://a360.co/3EO2viX.
Labels (1)
5 REPLIES 5
I'm not sure this is the best way to do this, but my suggestion is to use a bore toolpath, select the 3 faces and use "Order by Y" with "reverse order" enabled.
Here's a link to my test part: https://a360.co/3ER8Zxf, And attached is a video of what I did.
If there is a reason to not do it this way, I'd appreciate some feedback so I can learn better CAD/CAM techniques.
I hope this helps.
I'd do 3D adaptive through, then Circular to finish them all.
Please click "Accept Solution" if what I wrote solved your issue!
Your way is of course solve my air cutting problem, I really appreciate that, thank you very much.
However, I got an order and it says :" I want to clear the whole material in one cutting step with 0.2mm stepdown."
It means with every 0.2mm stepdown there is no material left and there is no return ( retract in milling process is undoubtedly acceptable ).
That's why I use Adaptive Clearance and meet air cutting.
Sorry for my ignorance but I try 3D Adaptive. It is working inside and material left outside is real thick, I don't think I could handle my old weak milling machine with that kind of procedure.
without your file I can't change anything, but modify your minimum stepdown, stock to leave, stock selection etc to get it to do what you need.
