Fusion Manufacture
Talk shop with the Fusion (formerly Fusion 360) Manufacture Community. Share tool strategies, tips, get advice and solve problems together with the best minds in the industry.
Cannot copy tool between projects
11 REPLIES 11
Message 1 of 12
brateris
468 Views, 11 Replies
Hello, I do not seem to be able to copy tools between projects. I have both projects open, and can see both sets of tools, but the copying either by control-c/control-v or dragging fails. See video below.
Any ideas?
11 REPLIES 11
Message 2 of 12
Mattxer
in reply to: brateris
Your video didn't attach.
Matt
Matt Smith
Software Engineer - MSmithDev - https://msmithdev.com/
CAD/CAM/CNC - Micro Insert Inc. - https://microinsertinc.com/
Message 3 of 12
brateris
in reply to: Mattxer
Message 4 of 12
seth.madore
Interesting, can you share your files? Right click on them and select "Share Public Link".
I'm curious if this is a Mac specific issue..
Seth Madore
Message 5 of 12
Mattxer
No problem,
It seems like it may be a bug. I am unable to replicate it on windows, maybe its osx specific. Have you tried restarting Fusion by any chance?
Matt
Matt Smith
Message 6 of 12
brateris
Yes, I have restarted fusion
Here are the files:
1: https://a360.co/2STFx1f
2: https://a360.co/2P4P3NT
Message 7 of 12
Sometimes the right-click dropdown is disabled when I open tool library for the first time, I have to right-click on some other tools before enabling the functions, not sure why?
First time opening tool library:
After right-clicking on other tools:
Message 8 of 12
TurtleRacing
Has this been solved? I am not able to copy and paste tools from one project to another either. Used to be able to drag and drop or copy and paste and now can't do either.
Message 9 of 12
jeff.pek
I just tried this and it worked for me. Are you able to do a screencast or other video of what you're seeing? I don't expect drag and drop to work, only right-click Copy/paste.
  Jeff
Message 10 of 12
TurtleRacing
in reply to: jeff.pek
Actually I can't. I just went to do the screen cast and it worked fine! I have tried this several times over the last few weeks and it hasn't worked. Nothing I did got it to work. When I posted earlier it wasn't working and I didn't restart or anything. I don't understand it.
It would be nice if the drag and drop worked though, but that's nothing to worry about.
Message 11 of 12
s.hanifan
I have tried repeatedly to use both ctrl C and the right click Copy Tools options to then paste into Excel as has been possible before.  I cannot copy my tool library and paste it outside of Fusion.
Message 12 of 12
seth.madore
@s.hanifan the issue you are raising is not the same issue being discussed in this thread. To prevent a sidetracking of the issue raised by the OP, I suggest starting a new thread and supplying as much detail as possible.
The original post refers to copy and paste between two active Fusion documents, not Fusion and Excel
Seth Madore
