Fusion Manufacture
Can you copy a set up from one file to another?
2 REPLIES 2
jscott6SWZG
90 Views, 2 Replies
I have tried does not seem to allow  would save more than a few keystrokes
I can copy tool paths
2 REPLIES 2
seth.madore
in reply to: jscott6SWZG
Yep, CTRL+C and CTRL+V will do it just fine. Are you not finding that to be the case, and would you have a screen recording of these issues?
Seth Madore
jscott6SWZG
in reply to: seth.madore
The dilemma with a screen cast is nothing happens.....and I still haven't figured a screen cast out???
What screen cast should i use (windows 11)
I got to the file the set up is to be copied from....
I left click right side button to activate it.
I right click on the set up title then select copy from the drop down.
I go to the destination file select manufacture
Right click on set-ups
AAAhhh there is paste
got it. i wasn't see the paste label, and didn't select set ups with ctlc and ctrlv
Thanks a lot
