Fusion Manufacture
Can't upload models
4 REPLIES 4
mbulgerDHJU5
94 Views, 4 Replies
Can't upload models
Cannot upload native .ipt files in to Fusion 360 from Inventor either through the Vault or our local server.
4 REPLIES 4
@mbulgerDHJU5 This should be addressed now. We have a short outage on our backend that we quickly addressed. Can you please confirm that it is working now?
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
Thanks  we are able to upload models again
seth.madore
in reply to: mbulgerDHJU5
@mbulgerDHJU5 did you also open a Problem report on the Insider forum? If your issue has been resolved, I'll close that task if it's okay with you?
Seth Madore
Is this the same issue I was having? I had 2 prts open properly yesterday and none this morning!
https://forums.autodesk.com/t5/fusion-360-support/uploading-through-the-program-doesn-t-work-online-...
Please click "Accept Solution" if what I wrote solved your issue!
