Can't set side compensation on trace path
chrisQX8DX
chrisQX8DX
i use trace quite a lot but now i'm running into a problem setting the compensation. Instead of switching the compensation from the inside of the curve to the outside of the curve it will only change direction but still trace on the outside of the curve. Not sure what's going on and how to fix it.
Can't share the file cause it's a production file. Here's a screencast of the problem:
https://autode.sk/3K9QWEt
The curve was generated using 'Include 3d geometry' for the curvy sides and then connecting the end points with a line to close the loop. I only connected the endpoints because the single curves would have the same problem and i thought closing the loop might fix it. Ands i only made these sketch curves in the first place because i couldn't select the proper edges from the model (because of a filet on the edge it wouldn't let me and selected random curves)
AppleSilicon Macos 26.4
GENERAL DISCLAIMER: if there isn't a file attached to my posts then there is a reason for it. Whenever needed or whenever i can i will attach a file for troubleshooting. If no file is attached i will always try to explain as clearly as possible and if needed or helpfull provide illustrative screenshots. When i have an issue that can only be helped by attaching a file which i cannot share publicly i won't ask about it here.
a.laasW8M6T
Set the compensation to Left(climb milling ) ,then to change which side of the contour you want to mill on, click the Red direction arrow near the Blue contour
Changing compensation from left to right isn't the correct way to switch the side of the contour to mill on
Andrew Laas
Senior Machinist, Scott Automation
