Fusion Manufacture
Can't select tool
1 REPLY 1
Cad4fish
134 Views, 1 Reply
Can't select tool
I can select my plasma cutter in "Manage" but it does not show up when creating a "Setup."  This seems to be an intermittent problem because sometimes I CAN find the tool when setting up.
1 REPLY 1
Marco.Takx
in reply to: Cad4fish
Hi @Cad4fish,
In your screenshots you see that the first on is your TOOL library.
And in the second screenshot you are in the MACHINE library.
That are 2 different libraries.
So you have to setup a machine within your machine library to use that for your setup.
If my post answers your question Please use Accept as Solution & Kudos This helps everyone find answers more quickly!
Met vriendelijke groet | Kind regards | Mit freundlichem Gruß
Marco Takx
CAM Consultant
