Fusion Manufacture
Can't get rid of continue rest machining error
2 REPLIES 2
jscott6SWZG
64 Views, 2 Replies
What do I hafta do to get rid of this error.
Continue Rest Machining: Cannot verify that the stock is transferred from the previous setup for rest machining. Verify that the model selections in both setups are the same.
2 REPLIES 2
jscott6SWZG
in reply to: jscott6SWZG
I guess you have to use components rather than bodies selected from the manufacture browser.
a.laasW8M6T
Continue rest machining only works with a single body or a component or multiple components, multiple bodies by themselves are not supported
For a part like yours(which really should be one body) you can select the component called "base" rather than the 4 constituent bodies.
also in your setup3 there is an erroneous selection of the Cam root component which is selecting the entire design tree. (this is caused by an annoying bug that's already been reported)
see attached for corrected file
