Fusion Manufacture
Talk shop with the Fusion (formerly Fusion 360) Manufacture Community. Share tool strategies, tips, get advice and solve problems together with the best minds in the industry.
Can't get 3D morphed spiral to work
4 REPLIES 4
GPTech2444
912 Views, 4 Replies
I can do a scallop but I can't do a morphed spiral. I get this error,
Warning: Unable to create morphed spiral because a cavity contains more than one core.
Warning: No passes to link.
Generation completed with 2 warning(s) in 262.0ms.
Warning: Empty toolpath.
Here is a screencast of what is happening.
Learn, Grow, Succeed.
Tags (2)
4 REPLIES 4
fonsecr
in reply to: GPTech2444
The current morph feature only supports doing morphed spiral between one-to-one pairs of contours. In this case I think that the outermost contour extends so far from the inner contour that morph wants to split it in multiple "pockets". However, we are adding an improved morph which will be able to handle more cases like this. Stay tuned.
That said, in not sure if morph is really what you want here. If the surface is actually flat then you should normally be using Horizontal or maybe 2D Pocket in open pocket mode. Only if the surface is curved it would be appropriate to use Morphed Spiral / Scallop.
René Fonseca
Software Architect
GPTech2444
in reply to: fonsecr
The surface at the top of the model is a 3D contour and I've set the bottom level just below that surface so the flat area of the model isn't touched in this step.
The scallop works perfect but I wanted to see if morphed spiral is better.
Thanks.
jeff.walters
Try putting a containment boundary around the just the the left boss area.
Jeff Walters
Senior Support Engineer, CAM
GPTech2444
in reply to: jeff.walters
Thanks Jeff, that sorted it. I thought the bottom level would do the same.
