Fusion Manufacture
Can't edit parametric vice
3 REPLIES 3
stanislawrWFEAS
137 Views, 3 Replies
after the last Fusion update when I insert parametric vice into the design, I can't edit vice's stock parameters, on the other hand if I insert my part into parametric vice's stock parameters are enabled. What am I doing wrong?
3 REPLIES 3
You have to right click on the vice in your parts tree and select "break link".
Make sure Capture Design History is also enabled IN your new part.
Please click "Accept Solution" if what I wrote solved your issue!
I'm fairly certain that (prior to update) one was never able to access parameters for linked components, only Derived and "Edit in Place" (and of course, breaking links)
Seth Madore
I imported a new part, then I inserted the vice and broke the link, but Capture Design History wasn't enabled. Thank you, guys:)
