Can't creat pocket
leoE4H8W
Can't creat pocket
leoE4H8W
Can someone help me design this pocket? I can't get the pocket tool path right, the pocket is 1.25" deep
g-andresen
please share the file for reply
File > export > save as f3d on local drive > attach to post
günther
leoE4H8W
The problem is in setup, when I try to click on the line to cut the pocket it only cuts the face and not the deep pocket.
programming2C78B
So can you attach it or not? Make sure bottom height is set right, and select the shape of the pocket for your geometry.
Please click "Accept Solution" if what I wrote solved your issue!
