Fusion Manufacture
Can someone help me add Machine simulation to my Robo Drill Post Processor?
1 REPLY 1
Madsenalex25
124 Views, 1 Reply
I have tried to add machine simulation capability's to my post without success. I used this guide https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Configuring-a-post...
Attached is my Post Processor, and Machine file (f3z).
This machine has a KME Trunnion which is controlled through the DPRNT Function, it has been modified to out put a M200 command before the A and C Codes.
I would use the Fanuc Inspection post as it would also give me Inspect Surface functions, but it uses G68.2 and outputs IJK and I need to output A and C Codes prefixed with an M200. If that could be achieved that would actually be a better option.
1 REPLY 1
yd_kwon
in reply to: Madsenalex25
It looks like you need to set up your post file again.
I tested by replacing your machine simulation file with the Fanuc default and it works fine.
Trouble Points
1. set capabilities
capabilities = CAPABILITY_MILLING | CAPABILITY_MACHINE_SIMULATION;
2. machine settings are reset in post file → different from machine simulation settings
I think you will have to write a new robodrill post based on the Fanuc native post to solve this.
Good luck.
Translated with www.DeepL.com/Translator (free version)
iCetnric - MFG
CAM-Fusion 360/Inventor
CAD-Fusion 360/Inventor
Before PowerMILL
