Fusion Manufacture
Can someone add Manual NC passthrough to the Milltronics turning Postprocessor?
1 REPLY 1
chjade84
116 Views, 1 Reply
EDIT:  I don't see an option to delete this thread so I'll post what I discovered in case it helps anyone else.  For "debugging" purposes I was just posting the passthrough Manual NC as the only operation selected because it was easier to see if it was actually outputting it to gcode vs scrolling through the lines of code to find it.  I was going to give up on trying to solve the error for now and just post the whole code and run it and lo and behold it posted fine.
Turns out the xOutput error is coming from posting only the passthrough code.  If I post the whole program (after adding the "onManualNC" fundtion from the link below) it has no error.
So don't post only a Manual NC passthrough, you've got to post some actual CAM with it as well.
Trying to follow the directions to enable it from here: https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/post-processor-man...
There is no "onManualNC" in the post from the Fusion download page to add the function onPassThrough after.  So I just added it toward the end and at at least puts the passthrough text in the code, but I also get the error above.  It only encounters that error when I post with the manual NC, it is fine, otherwise.
Now I get this:
Error: TypeError: xOutput is undefined
Error at line: 1927
Stack dump:
writeRetract()@C:/Users/Chris/AppData/Roaming/Autodesk/Fusion 360 CAM/Posts/milltronics turning.cps:1926
onClose()@C:/Users/Chris/AppData/Roaming/Autodesk/Fusion 360 CAM/Posts/milltronics turning.cps:2010
Failed while processing onPassThrough() for record 53.
Error: Failed to invoke function 'onClose'.
Error: Failed to invoke 'onClose' in the post configuration.
Error: Failed to execute configuration.
Stop time: Friday, July 14, 2023 4:52:29 PM
Post processing failed.
1 REPLY 1
seth.madore
in reply to: chjade84
Glad to see that you solved your problem!
Seth Madore
