Can NOT select Bottom Height
mmharris
mmharris
what is wrong with this model ?
2d adaptive is imported as a template and won't allow me to pick bottom face or edge of pocket for Bottom Height
can choose Model Top and type numerical value but that is not the normal Fusion work flow
same template allows me to pick bottom face or edge of pocket for Bottom Height in other models
so I assume it's the model
2D pocket has similar issues
what is going on ?
Joshua.Aigen
Hi @mmharris, The trouble I ran into was that you have a sketch still turned on/visible and in order to select the pocket face I had to click and hold for multiple selection.Forums3.JPG
Joshua Aigen
Workshop Supervisor
mmharris
thank you     turning off sketches works    problem SOLVED thank you
new knowledge for future issues
click and hold with sketches on did not work and still fails for me with this model
