Fusion Manufacture
Can I make a new component from a copy?
4 REPLIES 4
MJvandeGeest
98 Views, 4 Replies
Is it possible to make a new component from a copy component?
4 REPLIES 4
m.vangrouw
in reply to: MJvandeGeest
If you right click the component there will be an option to copy it. Once that is done, right click on the the top of the model tree, or a component or sub component and click "paste new" to add the copied component to that section of the tree. The "paste new" command does not maintain a parametric link between the original and the copy, while the "paste" command does.
Does this answer your question?
MJvandeGeest
Thanks, now it works. I did it before and it didn't work, now it dos 🙂
brettNF4GC
in reply to: m.vangrouw
What if i made the copy using the move/copy function and now i want to make it unique component so i can push/pull it without affecting my original i copied from.
m.vangrouw
in reply to: brettNF4GC
Hi Brett,
I don't know a way to do what you are asking and I don't see anything obvious after some quick testing. With that being said, I never use the move/copy command to copy things, so I'm not the best person to ask.
