can any help trying to get clean 5 axis tool path for feature on model
crunichie
crunichie
hey guys
looking to see if any one can help me get better /clean 5 axis tool path on the model feature attracted.
have tried the 5 axis flow and 3d contour (with multi axis turned on )
flow as you see get good path one side but not on the other  in setup 2 (also using offset surface )
then tried the 3d contour  with added multi axis had it doing the multi axis but can get it to do it again on setup 3 using a offset surface
tried also surface offset of the feature to go past so get sharp edge. but only some time get it to work any help or tip be great
Mattxer
One issue that multi axis has with most of the toolpaths (steep and shallow, 3D contour...) is it wont calculate undercuts so you might have to try different wcs's to get it to calculate right. Flow might work with some tweaking.
Matt Smith
Software Engineer - MSmithDev - https://msmithdev.com/
CAD/CAM/CNC - Micro Insert Inc. - https://microinsertinc.com/
crunichie
so try moving my datum  then re gen path ways ok i give that try thanks and let you know if that worked
thanks
Mattxer
You can use a tool called accessibility analysis (Under inspect) to check. Like so:
The red area's fusion wont cut (when using multi axis with contour or steep & Shallow) because its considered an undercut.
I made an axis perpendicular to that cone, then made a plane on that. Set this as your new datum for that toolpath.
Matt Smith
