cam with patterns
nikoDJ4GQ
cam with patterns
nikoDJ4GQ
Hello There.
I wanted to make a sequential cuted panel so i draw a model and then used the pattern to make it a full panel. Ok
So i was thinking that when i'd get to cam, the 2D pocket that i programmed for a single part of the panel would be reported on all the other. But then no, it looks like it wants me to select every contour ... Any idea on how to make it easy ?
like drawing one, pattern it to a hundred and then apply a cam to one and it reports it to all of em ?
Hope i'm quite clear coz i make my best as a french guy. Thanks for your answers !
LibertyMachine
Like this?
Seth Madore
Owner, Liberty Machine, Inc.
Good. Fast. Cheap. Pick two.
ivan.stanojevic
In CAM operation, select all of the contours from first instance and create a new operation. Then, right click on that operation and select add to new pattern.
Edit:
@LibertyMachine oops, you were quicker than me 🙂
Ivan Stanojevic
nikoDJ4GQ
WOOOOWWW okok now this is gonna make me win loads of time . Thanks a lot.. By the way, if i understand well what i'm doing, i only have to draw one and then to pattern cam it as big as i want it ! this is great. Really
LibertyMachine
That is correct. However, you WILL need to actually use the Pattern function and not the other method of copy/paste (in Model work space)
Seth Madore
patrick.emin
Bonjour, pour votre information, nous avons un forum en français  à Fusion 360 - Français - Autodesk Community
Patrick Emin animateur de la communauté francophone
Vous avez trouvé un message utile? Alors donnez un "J'aime" à ce message!
Votre question a eu une réponse satisfaisante? Voulez vous avoir l'amabilité de cliquer sur le bouton
 APPROUVER LA SOLUTION  en bas de la réponse qui apporte une solution?
Signez notre Livre d'Or
