- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi Wiser-ones,
Greetings for Australia!
I appear to have broken something in the attached model - after jumping around in the timeline to create a second part, I can no longer select any contour in any mode to generate CAM tool paths.
I can also not edit the two existing toolpaths. I can't select anything!
Any advice would be greatly appreciated - either settings I should change or strategies to export or rescue the components into a version that CAM will talk nicely with.
Fusion
