Fusion Manufacture
CAM Turning: How to drill off-center, to make a bigger hole..
1 REPLY 1
randypetrongelli
87 Views, 1 Reply
In our turn/mills, the lathe guys here commonly use a large spade type drill with a x-offset to make a hole bigger than the drill diameter. This works very well. Would this be possible to program in fusion?
1 REPLY 1
Yes, but you need to define two tools, both with the same tool number but different offset numbers. The first tool is a drill, the second tool is a boring bar.
Seth Madore
