CAM tools, (even after enabling cloud libraries ), It's not available in my 360 HUB nor on my local machine
BenzyMH
BenzyMH
Hello Fusion 360 lovely people
I have checked the Forums on that topic and followed their instruction but couldn't my issue solved, hope you can help me out guys :slightly_smiling_face:
I am now following a Tutorial on the Autodesk Fusion 360 channel on YouTube, (https://www.youtube.com/watch?v=LlCMyRv315U&list=PLmA_xUT-8UlKAYxrXxGVhQbvbvqqPm0ay&index=2) and when it cam to choosing a turning tool, I couldn't find it, In the video around the minute (14:00), where he chooses the CCMT Turning tool.
I will provide snips/pictures of my case so it can be helpful to understand what I have
My System Info
Manufacturer Hewlett-Packard
Model HP Z800 Workstation
Total amount of system memory 24.0 GB RAM
System type 64-bit operating system
Number of processor cores 6
My Graphic Card Info
Display adapter type NVIDIA Quadro 2000
Total available graphics memory 13047 MB
Dedicated graphics memory 1024 MB
Dedicated system memory 0 MB
Shared system memory 12023 MB
Display adapter driver version 9.18.13.2078
Primary monitor resolution 1920x1080
Secondary monitor resolution 1920x1080
DirectX version DirectX 10
Replies (7)
BenzyMH
Ok, here is where I am at,
I went to this link https://cam.autodesk.com/hsmtools
and downloaded all the tools,
and added them to my local drive on the path Autodesk mentioned and they came up successfully on the cloud .
but still can't find that specific tools, is there a place where has like a library if tools to download ?
My System Info
jeff.pek
Can you clarify where you downloaded the tool library files to?
  Jeff
BenzyMH
Hi Jeff,
I downloaded it to this path on my local drive (C:\Users\Myusername\AppData\Local\Autodesk\Autodesk Fusion 360\200809200142631\W.login\M\D20200415286823856\CAMTools),
And it was Automatically uploaded to the Cloud on my A360 Account.
My System Info
randyT9V9C
I create local copies of all my post processors, tool libraries, and machine configs, rather than using the problematic cloud libraries. My main issue it that when I switch teams the cloud libraries from my personal hub didn't follow me. Here are the local paths (taken from my sync scripts).
OSX paths:
# Local dirs
dir_posts="/Users/$USER/Autodesk/Fusion 360 CAM/Posts"
dir_tools="/Users/$USER/Library/Application Support/Autodesk/CAM360/libraries/Local"
dir_machines="/Users/$USER/Library/Application Support/Autodesk/CAM360/machines"
Windows paths:
:: Local dirs
set dir_posts=%HOMEDRIVE%%HOMEPATH%\Appdata\Roaming\Autodesk\Fusion 360 CAM\Posts
set dir_tools=%HOMEDRIVE%%HOMEPATH%\AppData\Roaming\Autodesk\CAM360\libraries\Local
set dir_tools=%HOMEDRIVE%%HOMEPATH%\AppData\Roaming\Autodesk\CAM360\machines
daniel_lyall
Sometimes you have to do a restart of the computer offline then load up fusion then reboot the computer go back online then if anything was stuck it should come through.
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
jeff.pek
I'm not quite following what the issue is. You said you moved them directly into the local cache folder. I assume you did this while Fusion was running. And you say that they got uploaded to your Assets project tools folder. Then you're showing your side data panel, and they're not there. The side panel should be showing exactly the same thing as the browser view of that project.
Do you have different hubs?
Jeff
BenzyMH
I apologize if i wasn't clear :slightly_smiling_face:
What i meant is in the beginning it was empty, and now its perfect, but i can't find the specific tool in the tutorials ,
so the tool
Image below shows the tools i needed , which i didn't find on the Autodesk website, so my question is, should i search manufacturers ?
I am still new to CAM
My System Info
