CAM Template editing and updating toolpaths
Hello!  I am toolpathing 14 sheets of material that will all have the same operations done on each of them.  I created a template with the operations and toolpaths I will be using in order to have a starting place for each sheet.  I would love to be able to edit the template and have it update the toolpaths on all of the sheets that I had previously used the template to create.  For example, if I originally set the template to cut at 100 in/min and then decided I want it to go at 150in/min... If I change it to cut at 150in/min on sheet 1 and overwrite my old template, all of the toolpaths that I used the old template on (the 13 other sheets) stay the same and I would have to change them all individually.
Is there a way to change one factor of the operation and have it update the toolpathing for all of the sheets at once?
Thanks!
Marco.Takx
Hi @Anonymous,
At the moment this isn't possible.
The only thing that you can do is selecting operations with the same tool and use Compare and Edit to change some settings.
If my post answers your question Please use  Mark Solutions!.Accept as Solution & Give Kudos!Kudos This helps everyone find answers more quickly!
Met vriendelijke groet | Kind regards | Mit freundlichem Gruß
Marco Takx
CAM Programmer & CAM Consultant
