CAM Simulation broken?! Not showing 'In Control'
Hi!
In the toolpath preview it shows that the last cut is done with compensation on, but when simulating it's showing like it's not compensated! Also the diameter of this tool is set as compensation point but in the preview it's below the programmed path.
Anyone an idea?
I think it's just showing the center of the tool after an another look
seth.madore
It's showing the multiple passes that are taking place, is it not?
Perhaps I'm missing your question....? 
Seth Madore
Laurens-3DTechDraw
During simulation, the center of the tool is always shown as the cutter path.
Laurens Wijnschenk
3DTechDraw
AutoDesk CAM user & Post editor.
René for Legend.
Thanks, I found out a bit later that day! I first thought it showed as an 'in computer' toolpath but later I noticed the small perpendicular lead in
