I am a relatively new user of Fusion and am working my way through some increasingly complex CAM setups for milling ciomplex shapes using an X-Carve as a renderer.
in my last carve I noticed that the bit for the finishing pass was relatively short, and the cut was relatively deep.
The milling head is a deWalt 611 and the chuck for the deWalt several times came in contact with the work piece as the milling head moved through a series of complex x/y/z manoevres with the bit head near the bottom of the work piece.
I have glimpsed in some tutorials complext setups which looked like people had set up their entire milling systems inside Fusion, I assume so collisions of this sort could be calculated and avoided.
If I wanted to start down this path, how would I do that?
