Fusion Manufacture
CAM setup for notching the edge of a thin sheet?
5 REPLIES 5
jskinner58
195 Views, 5 Replies
I want to mill a notch out of a thin sheet for a gauge/template.  Having trouble what milling operation to choose and setting up the operation as doesn't have a closed contour - it does but I just want to machine the notch.  I am clamping the back side and don't want the cutter to go there. And it is plastic and could be done in one pass for depth of cut.
5 REPLIES 5
seth.madore
in reply to: jskinner58
Press the ALT key and select the chain you would like to machine 🙂
Like this:
Seth Madore
jskinner58
I have the 2D contour set up except for the start and finish.  Would like it to lower outside the material and just cut in from the side although I suppose the plunge isn't a big issue.
seth.madore
Oh, in that case, you can give it a Tangential Extension to scoot it out further, or turn on Stock Contours (which does result in an odd move)
Seth Madore
jskinner58
Didn't see a tangential extension option but I changed lead in angle to zero and increased the lead in slightly to start beyond the sheet edge.  Thanks!
seth.madore
Seth Madore
