Cam Setup Dialogue box not showing
krummeck
krummeck
Good Afternoon
In the Cam Tab, I choose to create a setup but the dialogue box that shows the setup does not show. How can I access this box during setup that I can set the parameters, tools, etc?
Kind Regards
Phatwarren
HughesTooling
There's a chance it's been moved off the screen try Ctrl+Alt+R all at the same time to reset the layout, this will reset all toolbars and dialog. Another option is after clicking the setup icon press Alt+spacebar then press M then click and hold the left mouse button and move the mouse around and the window will move to the mouse cursor.
Mark
Edit just noticed the Alt+Spacebar trick doesn't work for the setup dialog. Hopefully the layout reset will do the trick.
Mark Hughes
Owner, Hughes Tooling
krummeck
Thank you Mark, Ctrl-Alt-R did the trick
