Cam operations for an easier work flow
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi all. I am running a small business. I would like to know if there is an easier way to do the toolpath generating. My current workflow works like this.
1. Customers buy the boards that I sell. I currently have about 30 products that I sell, made of 18mm mdf. I would like to make the the boards as ordered and don't want to make stock.
2. I have all the products as components in a project folder. So I select the products that I have to make. Insert them into an assembly called manufacture.
3. Copy and paste the quantities that I need then arrange them on the stock sheet.
4. Do the setup and stock selection.
5. Now this is where I think it could be better. First engrave then holes then contour and each time this process is the same and I have to select all the holes(I know about the select all same size function) all the engrave and all the contours on each sheet. And for each product the same method applies each time.
Isn't there a way to save the toolpath for each product. And when it is arranged. To do something like. Use component toolpath(witch you create in the component folder) to generate the toolpaths on the piece of stock. And then have a option to arrange toolpath by tools or operation. Thanks for the help.
Fusion
