CAM - Mirrored part offset?
zaaephod
zaaephod
Hello all!
Loving F360 more every time I use it!
I have this part, I'd like to mirror the toolpaths in CAM. It works, but how do I offset the mirror so the paths don't run into each other?
Thanks!
Z
Steinwerks
You'll need to make a work plane away from the part to use (offset plane for instance), as it just mirrors around the selected feature (in this case your part face).
I would suggest though that you consider using a 180° rotated pattern instead so your cut direction isn't reversed (which happens with a mirrored toolpath). Create a point around which to rotate on a sketch along the centerline of the part to do this properly.
Either method will require extraneous geometry of some sort.
Neal Stein
New to Fusion 360 CAM? Click here for an introduction to 2D Milling, here for 2D Turning.
Find me on:
Instagram and YouTube
zaaephod
Hmmm. Well, I do need a left hand, and right hand version of this part. Unless I'm misunderstanding, just a rotated pattern wouldn't be what I need. It's not a big deal, I do have both sides modeled. I just figured I'd try the CAM mirror.
Thanks for your help!
Z
Steinwerks
Looking at your part I'm not sure that the rotated toolpath will do what you need. I will have to look into it but won't be able to for a few hours at least. The mirrored one will definitely give you what you need but there are issues with reversing cut direction as mentioned.
Neal Stein
Find me on:
