Fusion Manufacture
Cam Help
19 REPLIES 19
Message 1 of 20
McclurSL76
524 Views, 19 Replies
Cam Help
how to avoid pockest on my 3d adaptive roughing pass?
19 REPLIES 19
Message 2 of 20
seth.madore
in reply to: McclurSL76
Boundaries are the best way to avoid things. There are other methods, such as capping the pockets with a Patch Surface and then including that in your selections (Model Override). If you would like to share your file, I'd be happy to take a look at it for you.
File > Export > Save to local folder, return to thread and attach the .f3d file in your reply
Seth Madore
Message 3 of 20
McclurSL76
in reply to: seth.madore
thank you here is the file. also if you wouldnt mind if you see any errors and or ways to optimize it please feel free to fix it or let me know what i need to do!
Message 4 of 20
seth.madore
While the Adaptive is calculating, some thoughts:
1) Your Scallop toolpath is extremely conservative. A .250" ball endmill should be in the area of .025" stepover. Assuming this is a wood body, it would result in a surface finish around 125 Ra, which is easily sanded down to a smooth surface.
2) There are some things you can do to speed up toolpath creation, at least for the purposes of working thru your processes. Turn off "Machine Cavities" and increase the Fine Stepdown amounts when you have "Detect Flat Surfaces" turned on.
Seth Madore
Message 5 of 20
McclurSL76
could you elaborate on #2
Message 6 of 20
seth.madore
On #2, refining of a toolpath to achieve desired outcomes is a time consuming task. To "fast track" that process, I find it's helpful to sometimes just use very loose/coarse settings to generate the "general idea" of what you're looking for. Once I get toolpaths in the exact area I want, or going the direction I want (in the case of 3D Finishing paths) then I turn my attention to adjusting the stepover and whatnot.
Seth Madore
Message 7 of 20
McclurSL76
also i am running throu hard wood and i am about to do a test run on the adaptive so if you have any quick tips on the adaptive let me know
Message 8 of 20
seth.madore
Are you looking to carve the part out of the solid block (turn everything to chips/sawdust), or are you expecting to end up with, essentially, a guitar shaped window?
Seth Madore
Message 9 of 20
seth.madore
For wood, and depending on "stoutness" of the machine, I wouldn't think twice about using "Both Ways", as wood tends to react to that (in roughing, anyways)
Seth Madore
Message 10 of 20
McclurSL76
solid block carving i am leaving a extra 2 inches on each side for clamps to o i cant run into that
Message 11 of 20
McclurSL76
by chance could you send me the f3d file with the needed fixes
Message 12 of 20
seth.madore
Sorry for the delay, I got sidetracked by some other matters.
So, by defining a few boundaries and changing some of our settings, we can achieve a toolpath such as this:
 See attached file
Seth Madore
Message 13 of 20
McclurSL76
i couldnt open that file since you are on the insider edition
Message 14 of 20
seth.madore
Doh! Sorry about that, I'll reproduce my work in the Production build...
Seth Madore
Message 15 of 20
McclurSL76
thank you
Message 16 of 20
seth.madore
Here you go. On this part, easiest and quickest was just to turn off "Machine Cavities"
Seth Madore
Message 17 of 20
McclurSL76
how do i do the outline cut like to fully cut it from the blank
Message 18 of 20
seth.madore
Turn everything to chips, or more of a silhouette style cut?
2D Contour for the latter, 2D Adaptive for the former.
Seth Madore
Message 19 of 20
McclurSL76
Everything to chips sorry for the delay
Message 20 of 20
seth.madore
2D Adaptive:
Seth Madore
