Fusion Manufacture
CAM 2D Contour chamfer with ramp = bad toolpath
3 REPLIES 3
torstil
145 Views, 3 Replies
2D contour, chamfer endmill 60deg, going down with ramp. This used to work...... Fusion360 had issues with 2D Contour Tabs before and this feels very similar problem. Works without ramp.
3 REPLIES 3
seth.madore
in reply to: torstil
That's an interesting result you've got there. Could you share your file here?
File > Export > Save to local folder, return to thread and attach the .f3d file in your reply
Seth Madore
torstil
Rather not publicly.... If I make a new sketch with new circle and use it as Contour selection it also fails, but if I cut other direction (other side of the line) ramp works fine....
seth.madore
You can right click on the file in your Data Panel and select "Share Link". Send that link to me in a private message.
If you're on a Personal Account, you'll have to export the file and then email it to me:
seth DOT madore AT autodesk DOT com
Seth Madore
