Fusion Manufacture
Talk shop with the Fusion (formerly Fusion 360) Manufacture Community. Share tool strategies, tips, get advice and solve problems together with the best minds in the industry.
C-axis not taking shortest path, rotating wrong direction. Mazak mill turn
3 REPLIES 3
larsNR7Y2
316 Views, 3 Replies
Running a few Mazak Quick Turn lathes with milling capabilities, this specific machine has a Fusion640t control.
Trying to do a simple engraving on the outer diameter of a part but having problems with the C-axis not choosing the shortest path.
As you can see in the image attached, the machine just finished the row above going to C-161.738 and the next order of operations is to go to C-161.588, a difference in 0.15 degrees, yet as you can see on the buffer window the next move the machine will do is C-359.789, so spinning the wrong way around the part.
It does this on every C-axis row in the program, spinning back and forth instead of taking the shortest path.
Anyone seen this before?
We're using the standard Autodesk post processor which can be found here: https://cam.autodesk.com/posts/post.php?name=mazak%20quick%20turn%20250-msy
Here is some of the code: https://p.ip.fi/7DGe
Labels (4)
3 REPLIES 3
DarthBane55
in reply to: larsNR7Y2
It has nothing to do with Fusion, usually it's a parameter in the machine, that dictates if it will do the shortest way or move according to the sign in front (for example -160. would move CCW but +160 would move CW, or vice-versa).
larsNR7Y2
You were absolutely right, and I do appologize.
I had to change A18 from 0 to 1 for it to use "Shortest path" approach, thank you.
DarthBane55
huh... no apologies needed, you asked a legit question, and you found your answer, that's what the forum is for, all good! 😀
Technology Administrators
