Fusion Manufacture
C and Y axis
4 REPLIES 4
Emre_Yucel
124 Views, 4 Replies
C and Y axis
Hello, can I do C and Y axis turning and milling in Fusion 360 base package license?
Or do I need to buy an extension and which commands can I use to do this process, can you share a document?
4 REPLIES 4
seth.madore
in reply to: Emre_Yucel
You can do C and X/Y milling with the base commercial license.
As for C/Y turning, that's not something we support at this time.
For reference, I have a Doosan Lynx 2100 LSY, and I program it entirely without the Machining Extension (aside from the occasional Toolpath Trim luxury)
Seth Madore
Emre_Yucel
in reply to: seth.madore
Hi, thanks for your support, but is there a webinar or technical document on how to do these operations and for me to learn?
Can you help me?
Emre_Yucel
Which commands can I use for C and Y axis
seth.madore
What toolpaths? All of the 2D and 3D toolpaths should work. Whether they use the C axis or program with XY is a function of your post processor.
If you're working with a machine that only has a Y axis and a C, you're obviously going to be limited to....2D Contour, Slot, Bore, Thread (not sure on those last two). For 3D toolpath, EXTREMELY limited; Project, I think this would be the only one that may work
Seth Madore
