BUG: Warning: Cannot plunge outside stock Even Though Helix Ramp is Selected
Fusion Version: 2.0.6231
I am creating a 2D Pocket Toolpath and for the Ramp type I have Helix selected. When the toolpath generates is gives a warning stating "Cannot plunge outside stock."  I have helix for ramp type selected so I see no reason for this warning to be issued.
s.noke71
Can you share the file?
it helps when trying to figure out whats wrong.
HughesTooling
The problem will probably be your minimum ramp diameter is too big, the warning is sorta wrong\misleading. Because it can't ramp you get the error it can't plunge. Try setting the minimum ramp to something quite small like 0.01"
Mark
Mark Hughes
Owner, Hughes Tooling
Thanks! The issue was the ramp diameter like you said. I adjusted it to a smaller value and it regenerated without a warning.
Unfortunately I cannot share the file as it contains confidential models. Thank you for your help though!
