Bug since one of the latest releases: CAM Setup deletes itself
Willa1980
Willa1980
Hi there,
this is how the bug appears:
In component A I have the model that I want to mill. In component B, I have a model of the stock that I am going to use. In the CAM workspace, I create a new setup where I select the origin from a selected point, and the "stock from solid" which is component B. I add some operations, e.g. hole drilling. In order to see the toolpaths, I hide component B. Now, everything that I setup before is forgotten, and the toolpath of the hole drilling becomes invalid.
Please fix this... :grinning_face_with_smiling_eyes:
Willa1980
I noticed that it doesn't matter if the stock model is in another component or in the same as the model that is supposed to be milled. Everytime everything is forgotten which makes it impossible to work with Fusion360.
Tianq
A defect CAM-2182 is logged to track this issue. In fact, we already noticed this issue and are working on a fix.
Dave
Dave (Qing) Tian
Willa1980
Ok, thanks for your reply. Any idea on the release date...? As there is no possibility in Fusion to revert to previous releases, I can't continue to work now.
Anyway, a possibility to go back to previous Fusion360 releases would be pretty handy, as it already happened quite often that an update with a new bug kept me from working.
