Bug, Post output folder not saving.
HughesTooling
HughesTooling
I made a copy of a post I use to experiment with and found the output folder selected on the post dialog does not stick between sessions. Posts I've used for a while work fine but any new posts and I just noticed an update to my cloud post go back to the default folder after restarting Fusion.
Thanks Mark
Mark Hughes
Owner, Hughes Tooling
jeff.pek
Hi Mark -
Please remind me: are you on Mac or Windows?
  Jeff
HughesTooling
Hi Jeff
I'm using Win 8.1.
This is the working post that remembers the output folder OK.
I made a copy to test and fix a problem with circular moves of more than 360° and found the copy didn't save the output folder between sessions. When I'd fixed the problem I uploaded the new version to the cloud and now that version doesn't remember the output folder either but the original copy I have on Dropbox still works even after editing and saving with the fix.
One thought, does the GUID at the top of the post file need to be different between version.
Thanks Mark
Mark Hughes
