Bug in CAM Pattern Mirror
marc.a.grossman
Message 1 of 18
marc.a.grossman
I came across what I believe to be a bug, or at least an oversight in the CAM mirror feature.
Basically, I often use my cnc mill to cut out sheet metal parts which I then bend. Most of my work in done in/on aluminum. Aluminum should always be climb cut assuming a low backlash machine, which a CNC mill is given it's ballscrews. When I mirrored a toolpath, I got the original that was a climb cut, but the mirror was a conventional. I think this a bug. The screencast shows the issue.
Replies (17)
Message 2 of 18
brianrepp
Hi @marc.a.grossman - I don't see a screencast, do you mind trying to post again?
Message 3 of 18
marc.a.grossman
My mistake. I thought I had attached the screencast. Oh, now I see I think I had tried to attach it, but clicked post before confirming the insertion of the screencast.
Message 4 of 18
Matthew-R
@marc.a.grossman
Thanks for sharing this with us. I've investigated this with our development team and they do know about this behavior. It is logged with them as CAM-1717. So, it is something that they are aware of, but there isn't a timeline that I can provide which would include this feature.
You mentioned using a Linear Pattern and in addition to that, another work around would be to use a Circular pattern of two instances about an axis that would serve as your mirror parameter.
Another option for the time being could be to duplicate the toolpaths that are to be patterned, and use the compare/edit feature to make them all be conventional cutting. Then put them into a mirror pattern and turn off “keep original”. All resulting operations will be climb cut because they are mirrored from a conventional toolpath.
I hope this info helps and let us know if you have any other questions. Thanks again and we really appreciate the comments in the Screencast and your continued support of Fusion 360!
Matt
Message 5 of 18
marc.a.grossman
It's definitely not a high priority item. As you mentioned there are plenty of work-arounds. I was only pointing it out so that you knew about it.
Love fusion360 and so glad to be windows/solidworks free. Keep up the good work.
-Marc
Message 6 of 18
Farzati.Scott
I am experiencing the same issue with using the mirror pattern.  When can a resolution be expected?  I see a ticket was created...
Message 7 of 18
Farzati.Scott
When can a resolution to the mirror function in CAM be expected?  A ticket was issued in February and several people have had this issue.  I too am coming across this bug in using Fusion.  This program is utilized for more than fancy models and renderings.  These parts many times go to production and CAM needs to be working solid on expensive CNC machines with modern tooling....
Message 8 of 18
Matthew-R
@Farzati.Scott
Thanks for posting to this thread. I've reached out again to the development team asking for an update on this issue. I hope to receive news from them within the next couple of days and I'll be sure to provide an update here. Thanks again for your patience.
Matt Reineck
Technical Support Specialist, CAM
Message 9 of 18
Matthew-R
@marc.a.grossman @Farzati.Scott
I received news back from the development team and this issue has been described as more of a feature request that a defect report. Currently though, this change cannot be simply implemented. It doesn't fit into the way that patterns are handled. I would suggest voting for this feature request on the idea station by following this link:
Mirrored Pattern with Proper Milling directions and Entries
In short, this isn't an easy fix. It is being considered as a feature enhancement for the future though.
Please let me know if you have any other questions and I would be happy to have them addressed.
Best regards,
Matt Reineck
Autodesk HSM Support
Message 10 of 18
Farzati.Scott
Then I would suggest that this so called feature be removed. Cannot have a
tool running in the opposite direction if you want to mirror the toolpath
on the opposite side of the part. Vari-flute carbide coated endmills are
meant for climb cutting and aren't inexpensive throw away items. We
aren't back in the stone age any longer...
Once again the focus is solely for the design of parts by Engineers and not
the more important factor of being able to manufacture and put into real
world production of them. Have come across multiple features as you
mention that have been discussed for years without any results.
Disappointing!
Message 11 of 18
It seems as though they could easily automate one of the "workarounds" create an option that will first change all of the toolpaths to conventional before mirroring. This is a major issue, I can't think of a single part we make that doesn't have a mirrored version. The Compare and Edit doesnt even allow me to change all of the toolpaths to conventional, you have to go and do them all one by one. Not convenient at all.
Message 12 of 18
FrodoLoggins
"this issue has been described as more of a feature request that a defect"
No, this is clearly a defect...
- Time Magazine’s Person of the Year 2006
- Apple M1 Max rMBP A2485 // Latest MacOS // Latest Fusion
- Usually working off files uploaded to Fusion as: Step, STL, SLDPRT. If it matters ask me.
Message 13 of 18
seth.madore
No, no it's not a defect. It's simply a mirror of everything, including the direction in which a tool goes
Seth Madore
Message 14 of 18
FrodoLoggins
Which no one would ever want to do...
Message 15 of 18
marc.a.grossman
Except that when you're an actual machinist you know there are times when
you want to climb cut and times when you want to conventional mill. The
mirror as-is is not a feature. It is definitely a bug... ask any machinist.
Message 16 of 18
seth.madore
Ahem...
I am an actual machinist 😉
A software bug is when something occurs other than what was intended. This actually IS intended, as it's just a low resolution implementation of a mirror toolpath. Quick and dirty...
Seth Madore
Message 17 of 18
andy.concept303
Just come across this same issue which is still yet to be addressed.  Mirroring the tool path for handed parts was quite a useful feature I thought, until I discovered the climb vs conventional issue.
Message 18 of 18
rhdfmail
The workaround is also "stupid" If I have to dupicate  say, 25 operations and then edit them to conventional before mirroring I can just dupicate and reselect the geometries/toolorientation for them as I program them OR Mirror them and then change direction on the mirrored ops
