Fusion Manufacture
Bug? A boss tapered bore simulation cuts straight instead of tapered
9 REPLIES 9
Message 1 of 10
amasters
290 Views, 9 Replies
I have a very simple part to machine that has a tapered shape.  When I chose bore and then the surface, it shows the tool path as having a tapered helix. But when I run the simulation it cuts the bore straight and showing red as it cuts into the tapered part.  What's going on here?  Am I making some error or is this a bug?
Attached are screen captures and the Fusion file.Tapered Part shown with tapered tool pathScreenshot 2023-09-28 144027.pngTapered tool path Front view Screenshot 2023-09-28 143721.png
9 REPLIES 9
Message 2 of 10
seth.madore
in reply to: amasters
Well that's interesting, here's what I get:
I assume you're up-to-date on your Fusion install, no pending updates?
For what it's worth, the code is posting out fine:
Seth Madore
Message 3 of 10
a.laasW8M6T
It does seem like a bug, because the in process stock generates correctly:
I thought maybe it was to do with using a square endmill but even if I use a ballnose it just show a straight cylinder in simulation.
Message 4 of 10
amasters
in reply to: seth.madore
Seth,
No pending updates. Win 11.  I tried on another PC and same result.
Message 5 of 10
seth.madore
in reply to: a.laasW8M6T
@a.laasW8M6T you're seeing a straight cylinder in Simulation? Are you also on Win11?
Seth Madore
Message 6 of 10
a.laasW8M6T
I am seeing the straight cylinder on My work PC which is windows 10, but am seeing the correct tapered simulation on my Home PC which is also windows 10.
Different processors and graphics cards on both which may be relevant?
Message 7 of 10
seth.madore
Interesting. I've shared this issue with our developers, and thus far, they are all seeing a tapered boss. Will keep poking at it..
Seth Madore
Message 8 of 10
engineguy
@seth.madore
Just throwing this one in for a little fun, I created a second tapered boss and used the same operation to toolpath and simulate both at once, the original still cut straight but the new one worked nearly correctly, weird 🙂 🙂 🙂
Very old PC, originally Win7 updated to Win10 when they were giving out the free update 🙂 🙂
Quadro 600 Graphics
Think it may be something to do with the actual Models, one works the other not, well here anyway 🙂
Message 9 of 10
a.laasW8M6T
I shut my work PC down for the weekend and now that I try that file again it simulates correctly so🤔
Would be a pretty hard bug to track down I think
Message 10 of 10
engineguy
@a.laasW8M6T
Yep, would agree with that, where would anyone begin with this one 🙂 🙂
