Fusion Manufacture
Break chip holes
3 REPLIES 3
Bnuno608
181 Views, 3 Replies
Break chip holes
Maybe my English is poor, but can someone explain the strategy to break chip holes?
I usually make a hole (example 8.5mm X 20mm dept) then I need to break the chip with a bigger drill tool, like 20mm diameter.
In powermill I change from simple drill to chanfer and it automatically change the dept for example 1.5mm Dept
In fusion what is the best way to break the chip or see how deep I should go with rapid drill ?
3 REPLIES 3
Bnuno608
in reply to: Bnuno608
Solved, was in heights menu, on bottom has a chanfer option
a.laasW8M6T
Hi
If I am understanding correctly, I think in English we would say "Break the Edge".
You can set the bottom height in the drill cycle to "Chamfer Width" or to "Chamfer Diameter"
and use a drill to break the edge of the hole
Bnuno608
in reply to: a.laasW8M6T
Yes that it, break the Edge
