Announcements
Bottom chamfer on curved surface?
ChrisJMW
ChrisJMW
Hi all,
I need to do a bottom chamfer on a 1.5" diameter curved hole.  The 1.5" diameter hole meets a 2.5" diameter hole.
Here's a picture showing some of the holes I need the chamfer on.  I'm thinking of using an Iscar top / bottom chamfer mill but can't figure out how to get Fusion to follow the inside curve.
ChrisJMW
No ideas?
LibertyMachine
I'll take a look at it in the morning, could you share your file, or a sample file with the feature you are looking for?
File > Export > Save to local folder. Return to thread and attach the .f3d file in your reply
Seth Madore
Owner, Liberty Machine, Inc.
Good. Fast. Cheap. Pick two.
ChrisJMW
For this particular job I wouldn't feel right sharing it.
I think I figured it out though........Trace seems to do the trick, but I haven't actually tried it.
LibertyMachine
Yes, Trace will work, although it is finicky. You could share the file privately if you prefer, I'm always willing to sign an NDA
Seth Madore
ChrisJMW
I quickly made up a separate model.  I don't think this one could upset anyone.
I also need to figure out how to nicely finish the radius around the top of the holes.  This is in 316SS.
