Fusion Manufacture
Boring Small Holes
2 REPLIES 2
richardsalzman
151 Views, 2 Replies
Boring Small Holes
Quick question.  I have some 4-40 tapped holes that are for set screws.   I would like to counter bore with a 1/8 inch larger hole that is about .300 deep.  I was thinking of using a 1/8 inch end mill to machine this small flat bottomed counter bore.  I CAMed the counterbore using a deep drilling cycle.  Just curious of there is a better way to do this.  I am not sure if you are supposed to use end mills with a deep drilling - full retract toolpath.  The material is 6061 aluminum.
2 REPLIES 2
You can certainly do this with a drilling cycle, endmills aren't great at plunging so feed rate should be fairly conservative.
Another thing to consider is that endmills do not actually have a flat bottom, they are slightly dished inward towards the center.
this normally isn't too much of a problem, but if you need a true flat bottom hole you need to use a counterbore or other suitable tool
Thanks.. That is very helpful!
