Fusion Manufacture
Boring Ops not working on lathe program
4 REPLIES 4
andrewKJFB8
106 Views, 4 Replies
I have a part that gets drilled with a 1.875" insert drill and then gets bored to 4.3314", I can't get his to work properly can you or anyone give me some tips?
That would greatly be appreciated.
Thanks!
4 REPLIES 4
seth.madore
in reply to: andrewKJFB8
Would you be able to share your Fusion file here?
File > Export > Save to local folder, return to thread and attach the .f3d/.f3z file in your reply.
Seth Madore
andrewKJFB8
in reply to: seth.madore
Sorry where do I do that?
andrewKJFB8
here it is
a.laasW8M6T
Hi
Your Inner diameter is the model ID so the toolpath cant see anything to machine:
It should be something like this assuming you have drilled the 1.875" hole already
See attached
