Bore Order By Depth
Bore Order By Depth
campbellqn
Bore Order By Depth
campbellqn
I believe Ive found a bug in the bore operation. I have a plate that needs a series of bores and counterbores. When I select counter bore (larger hole towards to the top) and the main bore the operation is fine, but as soon as I add select all same diameter it starts with the inside (lower hole) resulting in a rapid collision.
seth.madore
Interesting.... Can you share a sample file that is exhibiting this behavior?
File > Export > Save to local folder. Return to thread and attach the .f3d file in your reply
Seth Madore
campbellqn
Playing with all the settings I cant seem to get it do the bores in order of depth by hole rather then depth across the part.
daniel_lyall
Now that is really bad.
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
Ryan_Fab
I confirm it was!
seth.madore
I have logged this as CAM-16827
As a work around, you CAN program up one bore as you desire and place that in a Duplication or Linear Pattern folder. That will give you better control over how things are run.
Seth Madore
