Fusion Manufacture
Bore Milling
4 REPLIES 4
marc5KGCS
334 Views, 4 Replies
Bore Milling
Post Processor does not support Bore Milling. How Do I resolve that?  I have the post processor attached.
4 REPLIES 4
a.laasW8M6T
in reply to: marc5KGCS
Hi
The bore milling option under the drilling menu is designed to primarily use a machines controllers built in cycles, like Heidenhain Cycle 208.
It would be better to use the 2D bore cycle:
marc5KGCS
in reply to: a.laasW8M6T
Wow! For all those years I have been using fusion, somehow i managed to over look that option....
Thank you!
marc5KGCS
Another question on the same project... When applying a contour on something like the attached, is selecting each part individually the only way to go, or am I missing something on that matter also?
yd_kwon
Patterns can be used to reduce the amount of selection.
A rectangle pattern is usually a good choice.
In the model you posted, I think you only need to select 2 shapes because they are specified as components.
Please take a look at the attached file.
CAM-Fusion 360/Inventor
CAD-Fusion 360/Inventor
Before PowerMILL
