Fusion Manufacture
bore milling in drill Operation no longer possible with Face mill!?
4 REPLIES 4
marcus.toepke
95 Views, 4 Replies
Hi all!
I am of the opinion that I have done the bore milling before with Face Mills!
But now it no longer works!
Or am I mistaken that it was possible and if so, why can't it be done!????
With flat endmill all work fine!
But with face mill:
I could of course just create a flat endmill as a facemill, but then the output in the tool list would be completely wrong.
If I were working alone this would not be a problem, but I would give the whole thing to work through!
4 REPLIES 4
engineguy
in reply to: marcus.toepke
@marcus.toepke
Hmmm, maybe it was the 2D Bore toolpath that you used before ?? That does work with a Face Mill Tool 🙂
File attached.
marcus.toepke
in reply to: engineguy
Yeah I know that it works with 2D bore mill, but it results in masses of data, with the cycle version I have only a nice cycle! 😉
Even if I am wrong and it was not possible before, it is still very incomprehensible why tools that work well for such operations are blocked!
seth.madore
Because it's a "Drill" cycle (yes, you've selected Bore, but it's primary action is "Drill"), I don't think a Facemill has ever been possible for selection. I can ask around as to the "why", but it may take a bit.
Seth Madore
it may be preventative since most face mills are not center cutting and can't blind bore into a hole unless its a certain % of the tool Dia. I'd just cheat with an endmill of the same Dia and tool # or use 2D bore, as suggested. I didn't even know you could from the Drill menu.
Please click "Accept Solution" if what I wrote solved your issue!
